How to obtain the SGS turbulent kinetic energy in LES model |
gen pei
Rep Power: 7 ![]() |
Dear Experts,
I am using the LES model to simulate the room airflow on StarCCM+. I would like to compare the contour of total turbulent kinetic energy to the RANS model. I am aware that the total turbulent kinetic energy of LES has resolved and SGS parts. Now I can calculate the resolved part using field variance (thanks to this forum). But I still don't know how to obtain the SGS turbulent kinetic energy (after searching the forum). I used the WALE SGS model and seems there is no built-in function for this. I tried to create the new field function but I had difficulty defining this value. The equations in guidebook shows the SGS Tke is the function of strain rate tensor. I have no clue how to define it as field function. Please let me know if you have any advice. Thank you. Regards, Gen Pei |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
If you enable temporary storage retained then the modulus of the strain rate tensor will be available as a field function which is all you need.
The strain rate tensor, being a tensor, is somewhat tricky to define using only vector field functions. |
TheIndianLel
You can activate aeroacoustics model(even if you are not going to use it) to get the in-built SGS Turbulent Kinetic Energy variable.
les;sgs |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 18:19 |
turbulent kinetic energy, LES | Cheese | CFX | 4 | January 5, 2019 17:45 |
2D LES simulation of turbulent jet | adnan.nweilati | FLUENT | 6 | December 3, 2014 09:33 |
sgs turbulent kinetic energy | blons | Main CFD Forum | 0 | February 25, 2010 12:16 |
