Problem with cells transition in a trimmed mesh |
April 26, 2020, 12:41 |
Firstly, thanks in advance for the answers. Using STAR CCM+ I have a problem with the trimmed mesh. As shown in attached pictures, it occurs a horrible transition in the cells growth. It must be said that transition occurs only in that area. I'l try to be more clear. If i change the Base Size, the problem occurs in the same cell variation point (in my case, starting from the biggest cells, it is from the fourth to the fifth cells dimension). Using a volume control, it changes where the problem is but it still occurs . Changing the Volume growth rate doesn't help.
Any suggestion about how to solve? |
trimmed mesh |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
