April 25, 2020, 04:26 |
CAD projection surface mesh help
Alessandro Donadeo
Rep Power: 6 |
I am creating a surface mesh for my wind turbine. If I create the mesh by deactivating "CAD projection", it creates strange areas with coarse cells on the outside of the blade (figure 1), if instead if activated "CAD projection" creates coarse striped areas on the inside of the blade (figure 2 ). Anyone know the reason? |
April 27, 2020, 00:25 |
Ping
Rep Power: 20 |
this is strange but the surface mesher will very occasionally create local fine patches for no logical reason but this is not what you have.
what does the surface mesh of the cad of the blade look like that is your input to the surface mesher and does its mesh match in some way what you see in those remeshed surface? maybe try re-tessellating the cad to a coarser or finer setting in parts. i suggest you check these things - your cad might have multiple surfaces near each other; there are other surface near the blade that are affecting the meshing; turn off proximity and compatibility refinement; |
cad projection, mesh, surface |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
Extracting volume from surface CAD mesh | vjewtou | STAR-CCM+ | 2 | May 13, 2017 15:14 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 09:52 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
