Help with STAR CCM solution diverges
Old   April 23, 2020, 10:29
Default Help with STAR CCM solution diverges
Ducreux
Gui92200 is on a distinguished road
I have an problem on my simulation on STARCCM. Everything seems to work fine until I have some issues (check the picture). I can see that the solution diverges at one moment.
The problem is that the calcul time is already huge and I can’t use a thiner mesher.
The system tested is a system aiming at separating oil and gaz from a melange with a rotor rotating at 10000 rpm.
Here are some technical feature I used to run the simulation :
Physics Models :
Segregated flow (VOF)
Multiphase interaction
Implicit unsteady
Three dimensional
Two Layer All y + wall treatment
Gravity
Exact wall distance
Gradients
Volumic mesher :
Surface remesher,
automatic surface Repair
Tetrahedrale Mesher
Prism Layer Mesher
Base size 0.005
Pert Part meshing
Surface curvature 90
Help appreciated !
Thanks
Guillaume
Gui92200 is offline   Reply With Quote
Old   April 24, 2020, 01:40
Ping
ping is on a distinguished road
vof is not really the correct multiphase model for separation although there are some recent additions that might help a little. i suggest you use eulerian multiphase - the help explains what the wide range of multiphase models are good for.
ping is offline   Reply With Quote
divergence detected, solution, starccm
Marine Propeller Hydroacoustic Simulation in Star CCM BlackEagle STAR-CCM+ 1 December 8, 2017 22:33
problem when imported geometry from 3D CAD to star ccm, TAREK GANAT STAR-CCM+ 1 May 21, 2013 23:15
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
Fluent Vs Star CCM firda Main CFD Forum 3 February 26, 2011 03:51
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
