April 23, 2020, 07:07 |
Heat Transfer with Surface Parameters
Onur
Rep Power: 8 |
Hey there,
Currently I am working on cooling 5 chips each providing 200 Watts of heat to a cooling plate. Water is used as a working fluid through the channels created in the cold plate. I have done analysis with smooth pipe surfaces; however, I would like to see the impact of rough surface on heat transfer. Now I tried assigning a roughness height of 0.5mm but nothing really seemed to change. Then, I realized there are more parameters (Wall Roughness Parameters) that I can adjust. Do I need to adjust these numbers are they are fine on their own? Or the surface height I have given is too little to make any difference? Geometrical Properties of pipes and cooling plate: -Rectangular cross section -2mm height. 14mm wide cross section -50cmx50cm cold plate Boundary conditions: -2m/s velocity inlets -Pressure outlets at 0 Pa -The pipes start with circular inlet with 10mm diameter and makes a smooth transition to rectangular pipes (Can be seen on pictures) Note: The roughness is assigned on the interface boundary between the base and the fluid. I suppose that's where I need to assign the roughness.. |
heat transfer, pipe flow, surface roughness |
Interphase mass transfer of a reaction | cfx_ws1992 | Main CFD Forum | 0 | May 15, 2017 22:42 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 16:03 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
surface to surface radiation heat transfer? | suresh | Siemens | 1 | July 7, 2006 07:54 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
