April 17, 2020, 10:11 |
Mesh refinement field function
Alessandro Donadeo
Rep Power: 6 |
Hello.
I would like to create, if possible, a mesh refinement field function. I would like to refine the mesh around some curves. (belonging to the geometric parts) The result should be a sort of tubular structure, where each point of the curve has a portion of spherical space with refined mesh around it. What expression can I use to define the function? |
September 7, 2020, 10:28 |
Table-based Mesh refinement
Bill
Hi Alessandro,
https://apps.dtic.mil/dtic/tr/fulltext/u2/1069198.pdf Here you can find an idea about how to proceed with your question. Greetings... |
curve, field function, mesh, refinement |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] Not Able to Refine Mesh in Refinement Box | noodleluvmay | OpenFOAM Meshing & Mesh Conversion | 2 | January 27, 2020 10:55 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
