Simulating both solid and fluid regions
Old   April 14, 2020, 00:03
Default Simulating both solid and fluid regions
asdf
ryan.kong62@gmail.com is on a distinguished road
Hi All,
I want to simulate the heat transfer of a liquid LBE in a closed loop. The geometry is a little bit complicated. I have generated the solid structure using Solidworks. How should I extract the internal volume for the fluid domain and mesh both the solid and fluid volumes?
Thanks,
Ran
ryan.kong62@gmail.com is offline   Reply With Quote
Old   April 14, 2020, 04:55
Lucky
You can do it in either solidworks or star-ccm. Create a water-tight solid and subtract your solid from it. In solidworks, you find it in create mold iirc.
Old   April 14, 2020, 11:18
asdf
Hi LuckyTran,
Thank you for your reply. I did it in Star CCM using "extract internal volume". However, when I mesh the parts, it keeps telling me that "patch is shared by more than two part surfaces". I understand that I may need to do the surface repair. I have studied the manual but I still have no clue how to do it.
One question is when I use "extract internal volume" in Star CAD, does it generate two faces at the interface? one belongs to solid and the other one belongsto fluid? What about "subtract"? Does "subtract" also generate two faces?
Old   April 15, 2020, 03:03
Lucky
How about... we don't open a can of worms.
I recommend you try on a simple geometry like a cylinder in a box to clear some of your doubts.
Old   April 16, 2020, 01:42
Ping
ping is on a distinguished road
since you created your cad in swx it should be in a good condition compared to some of the dodgy surfaces some users have to use.
i suggest you import into the cad tool of star ie open a new blank cad model and import the swx parasolid part. ensure you use parasolid and not some inferior cad translated format since star like swx uses parasolid for solid modelling.
then do the internal volume extraction in cad and then imprint the two bodies onto each other since this creates the required contacts between the two contacting surfaces of the solid bodies.
then transfer the bodies into geometry and there is a good chance that you will have no problems.
avoid surface repair other than for finding where your problems are and then fixing them back in cad or with better mesher settings - only repair when you really do have bad cad in the first place.
ping is offline   Reply With Quote
[solids4Foam] How to calculate drag coeff when using solids4Foam amuzeshi OpenFOAM CC Toolkits for Fluid-Structure Interaction 15 November 7, 2019 13:50
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
