Alex
Rep Power: 0 ![]() |
Hey
I'm trying to create a fluid domain for my sim with custom volumetric controls to cut down computation time. I have 3 cuboidal volumes of decreasing size, each with increasingly finer meshes inside each other to simulate air flow over a complex blunt body. The meshes themselves are fine and look good however i am having troube with my regions and boundaries. I have looked at the tutorials in the STAR CCM+ manual but cant quite get it since the air does not flow inside the other volumes. I want to have a single stangation inlet and pressure outlet on the outermost volume and have the boundaries of the finer meshes not affect the flow of the air however i can't get this to work. I dont know if it's because i have set up the regions wrong or my parts (and surfaces). Currently i have a region for each volume(part) plus one for my blunt body. If anyone knows how to do this please let me know asap. Thanks Alex |
Yogesh Nalam
Rep Power: 13 ![]() |
May be you could a picture of your problem. Hope your interfaces are well created between your regions.
Rep Power: 24 ![]() |
You do not need 1 region for each volume. You should only have 1 region for them all. Use a volumetric control and your cuboidal volumes to control the mesh size. It's probably best for you to review the meshing tutorials, as I'm sure this concept is covered.
boundary condition, mesh 3d, star ccm |
y+ = 1 boundary layer mesh with snappyHexMesh | Arzed23 | OpenFOAM Running, Solving & CFD | 6 | November 23, 2022 15:15 |
Cyclic boundary condition in foam-extend 4.0 | rellumeister | OpenFOAM Pre-Processing | 2 | March 3, 2020 08:03 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
