March 9, 2020, 13:48 |
Residual graph issue
Emmanuel Sarpong
Rep Power: 7 |
I am running a simulation for flow over 2d cylinder. I ran a laminar-turbulent case at from re=100 to Re=10K. I was comparing the drag values to a paper and most values were similar. I could visualise vortex shedding and vector scene. However, i was told that my residual graph is wrong and so the solver is not stable. I don't know what part of my setup is wrong and i need to apply this case to several bridge deck sections. If anyone has any solutions please help.
SetUP Domain: 4m by 6m(hxL) Radius of cylinder:0.05m Meshing: Surface Wrapper, Polyhedral, Surface Meshing Values: base size:20cm thn 2 volumetric controls of 2cm and 1cm aruond the wake of the cylinder Physics: air (Standard), coupled flow, implicit unsteady, k-epsilon, velocity is 0.2m/s Time step is 0.05s (second order discretisation) courant number 0.5 |
March 9, 2020, 16:34 |
Matt
Rep Power: 18 |
It is necessary for us to see your residual plot in order to diagnose issues with it. Can you upload a copy?
March 9, 2020, 17:48 |
Emmanuel Sarpong
Rep Power: 7 |
the residual and mesh are attached. Actually the re=10K is definitely wrong
March 10, 2020, 06:08 |
Marco Riedel
Rep Power: 15 |
The residual plot shows per default the normalized residuals. If I understood it right, Star divides the actual iteration through the average value of the first 6 iterations. Sometimes the residuals look better, if you switch the normalization option to off.
March 10, 2020, 07:22 |
Emmanuel Sarpong
Rep Power: 7 |
thank you for your feedback. It has improved the graph and looks within the range but the spiking seem abnormal to me
March 10, 2020, 07:23 |
Emmanuel Sarpong
Rep Power: 7 |
heres the graph
March 10, 2020, 07:53 |
Marco Riedel
Rep Power: 15 |
Phew, as a next step I would look at the solver settings. But first of all I would try to solve the case with the segregated solver. If you don't see problems in that case, you know that you have to work on the (coupled) solver settings .Something like Courant-number, Underrelaxation factor or the convergence accelerator. Also a good initialization may help you.
March 10, 2020, 08:08 |
Emmanuel Sarpong
Rep Power: 7 |
yh i will try the segregated solver and see what i need to do with the coupled solver. I will let you know what happens
March 10, 2020, 11:08 |
#9 |
Lucky
Rep Power: 66 |
Make a report of a solution value (velocity, pressure, temperature, etc.) and also make a monitor and report of it and check that it is asymptotically converging.
Isn't this a transient simulation? In which case the residuals makes 100% sense. |
March 10, 2020, 13:24 |
#10 |
Emmanuel Sarpong
Rep Power: 7 |
i tweaked the under-relaxation factor. this 2 Capture4.PNG and the other is 0.5Capture5.PNG. but i turned the normalisation on again to see if it was similar to what was happening before.
March 10, 2020, 13:25 |
#11 |
Emmanuel Sarpong
Rep Power: 7 |
someone said it was wrong but they were comparing to OpenFOAM residuals which i am pretty sure uses a PISO solver
March 11, 2020, 11:37 |
#12 | |
Lucky
Rep Power: 66 |
The reason it spikes is because the 1st iteration of the new time-step uses the final solution of the previous time-step as the initial guess. The solution to the previous time-step will always be different than the new time-step unless your flow is completely stationary. So you are always guaranteed to see a spike. PISO if done the PISO way is iteration-less (1 iteration) so of course the residual plot will look very different. |
March 12, 2020, 07:43 |
#13 |
Emmanuel Sarpong
Rep Power: 7 |
thank you for explaining the residual graphs to me. I will try and improve on the setup to see if anything changes
March 13, 2020, 11:48 |
#14 |
Emmanuel Sarpong
Rep Power: 7 |
i was able to obtain sufficient results for the cylinder case however now i am applying the same setup to the a bridge deck do you think these are acceptable residuals or should edit the setup further
meshing, residal, residuals every iteration, star ccm+ |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 13:50 |
Suppress twoPhaseEulerFoam energy | AlmostSurelyRob | OpenFOAM Running, Solving & CFD | 33 | September 25, 2018 18:45 |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 13:30 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 13:50 |
