Problems in mesh for an car model in star CCM+(surface intersects)
Old   March 2, 2020, 14:49
Default Problems in mesh for an car model in star CCM+(surface intersects)
super visor
supervisor 101 is on a distinguished road
Dear Forum Users,
I am working on a CFD analysis of a Car. I created a wind tunnel and using transform just bought the car near to the symmetry wall of the wind tunnel.
while almost all of my parameters are correct. I couldn't figure out what is the main cause of this error (surface intersects itself) and how do I troubleshoot this.
I have attached the figure, any suggestions or procedures to remove this problem, shall be highly appreciated.
Thanks in advance
supervisor 101 is offline   Reply With Quote
Old   March 3, 2020, 02:04
demirel suleyman
dmirel is on a distinguished road
There is a function called Repair Surface. If you right-click one part you should see it. Your problem can be from the geometry, it intesects itself or because your surface mesh is too coarse in some areas . The root cause can be checked with this function I've mentioned earlier. You can find more information in the user manual.
I hope this helps,
Demirel
dmirel is offline   Reply With Quote
aerodynamic analysis, car aerodynamics, cfd, star ccm+
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
Problems in surface repair/mesh for an car model in star CCM+ supervisor 101 STAR-CCM+ 1 February 26, 2020 10:04
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 19:48
