Selecting surfaces with Surface Segments gives no options
Old   February 29, 2020, 19:59
Default Selecting surfaces with Surface Segments gives no options
David
cfddude2 is on a distinguished road
I'm trying to apply surface constraints on my part with Surface Segments. When opening the surface selection dialog box, no options are listed.
I have split the geometry part up so that the surfaces I want to constrain are isolated from the rest of the part, and they are already recognized as surfaces/boundaries in the region. I'm confused why there are no eligible surfaces to constrain. Is there restrictions to what kind of surface can be selected?
https://imgur.com/a/3HAtafT
cfddude2 is offline   Reply With Quote
Old   July 10, 2021, 07:50
Pietro
pi120 is on a distinguished road
In case anybody faced the same issue, I solved this problem deleting the interfaces associated with the part surfaces that I wanted to select
pi120 is offline   Reply With Quote
constraint, fixed, segment, star-ccm, surface
[snappyHexMesh] SHM doesn't create cellZones for one region Eko OpenFOAM Meshing & Mesh Conversion 10 January 24, 2018 03:03
[snappyHexMesh] SHM not snapping to some surfaces Swift OpenFOAM Meshing & Mesh Conversion 13 January 4, 2016 02:56
[snappyHexMesh] snappyHexMesh not refining surfaces Hydro1004 OpenFOAM Meshing & Mesh Conversion 3 August 29, 2012 12:56
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
Calculating forces on a non-closed surface ScottN FLUENT 0 March 1, 2011 18:18
