February 14, 2020, 19:27 |
Steady VS Unsteady
Rep Power: 6 |
Hello
So I did a simulation with steady model of a laminar forced convection flow with Segregated flow, Steady But when I'm trying to get same result with unsteady models like coupled flow (or segregated), implicit , .... the result is totally different. You should be able to get same result. Like if the boundary conditions are not changing, same results should be obtained over time and you should reach to the steady state. where is the problem??!!! |
February 15, 2020, 19:19 |
Rep Power: 24 |
Are you performing temporal averaging and comparing that field to the steady result?
The results will not be identical, in any case. |
February 15, 2020, 21:12 |
Rep Power: 6 |
I am not doing any averaging on the data. But even doing averaging shouldn't change anything since the flow is steady.
The results should be the same since the flow is steady. If you use an unsteady model for a steady flow, as the time goes on, the steady state should be reached. |
February 15, 2020, 23:25 |
Rep Power: 24 |
Is the unsteady case producing an unsteady result?
You could make it more steady-like by increasing the timestep a lot. |
February 16, 2020, 00:17 |
Rep Power: 6 |
It's weird. After couple of time steps, the solution is not changing.
Definitely it's not the steady state because it is different with the result obtained by steady model. |
February 17, 2020, 13:37 |
Lucky
Rep Power: 66 |
Is the steady case even producing a steady result? Most of the time, it doesn't.
Regardless, I wouldn't expect always the same result. They can be different. |
Simulating an unsteady phenomenon with a steady model | JochemGrietens | Main CFD Forum | 2 | April 13, 2016 11:51 |
How to compare unsteady (pimpleDyMFoam) results to a steady (MRFSimpleFoam) | Kossivi | OpenFOAM Running, Solving & CFD | 0 | April 4, 2016 22:09 |
Steady and Unsteady computations | Luttappy | FLUENT | 2 | March 9, 2016 05:46 |
steady to unsteady | wlt_1985 | FLUENT | 6 | December 4, 2010 16:17 |
steady and unsteady conditions | uday | Main CFD Forum | 0 | November 17, 2009 05:17 |
