FLEXnet error: (-15,10)
Old   February 12, 2020, 09:22
Default FLEXnet error: (-15,10)
ceren
ronin11 is on a distinguished road
Starting local server: starccm+ -server -rsh ssh
Serial process 3392
STAR-CCM+ 13.06.012 (win64/intel16.3-r8)
License build date: 02 February 2017
This version of the code requires license version 2018.10 or greater.
Licensing problem: Unable to find a path to any license file or license server. Please create the CDLMD_LICENSE_FILE environment variable and point it to the license server.
I have problem.I used to STAR-CCM+13.06.012-R8 Win64.How can i solve the problem?
ronin11 is offline   Reply With Quote
Old   February 12, 2020, 20:11
Vitaly
Pigrenok is on a distinguished road
Where is your licence server? Is it installed locally or do you use the remote one? If remote, you need to know exact address similar to this 27000@licence.host.com (obviously yours will look differently). If you do not know it, talk to the network admin.
If you are going to install your own local FlexNet server, then this link
https://www.originlab.com/doc/Licens...urrent-Windows
probably will help your (this is for Windows, for Linux it can probably be very similar, but you should be able to find some tutorials). For this you obviously need the licence file supplied by the vendor (Siemens in this case). When you start your licence server, or will tell you which address to use.
After that you need to create an environment variable in your system called CDLMD_LICENSE_FILE with the value of the address of your licence server.
I hope it helps.
Pigrenok is offline   Reply With Quote
Star-CCM+ FLEXnet Error Cam7 STAR-CCM+ 0 January 20, 2018 03:47
ANSYS License Manager Error, FLEXnet Licensing Error: -97, 121 p.sarafraz ANSYS 4 June 1, 2016 14:39
Server License issue - Flexnet Publisher RayPowers Siemens 0 September 11, 2013 13:18
