Pressure distribution around the circular cylinder |
Craig Yau
Rep Power: 0 ![]() |
I am currently doing a project at Uni simulating flow around a circular cylinder.
I am very new to Star CCM+. I got everything working well, but I am having trouble plotting pressure distribution around the circular cylinder. Are there anyone who can help me, giving me an idea of how I should approach the problem? Thank You |
Vitaly
Rep Power: 10 ![]() |
Could you please clarify what do you mean by "pressure distribution around cylinder"? Also, against what do you want to plot the pressure?
What your are possibly after is over of the probes. If you want to plot pressure against time, then point probe is what your are looking for. Otherwise, of you want to plot pressure against space (spatial distribution) then probably you should start with the line probe and then possibly use more complex ones. |
Rep Power: 24 ![]() |
I would avoid line probes for this.
It's best to make a section plane and intersect it only with the cylinder surface. Then put a cylindrical coordinate system inside the cylinder and create an XY plot using the plane in that coordinate system. |
cylinder flow, post processing, pressure coefficient, star ccm |
Pressure fields in FOAM, p field, total pressure, etc. | Tobi | OpenFOAM Post-Processing | 9 | March 25, 2022 01:33 |
how to get the mean pressure coefficient around a cylinder | zhangqin200000 | OpenFOAM Post-Processing | 4 | August 30, 2017 14:07 |
CFX Solver stopped with error when requested for backup during solver running | Mfaizan | CFX | 40 | May 13, 2016 06:50 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Turbulent steady flow around a circular cylinder | Mirek Kabacinski | FLUENT | 0 | July 23, 2003 18:40 |
