Different calc for lift between: force coefficient report and 6-DOF body force report
Old   January 15, 2020, 10:16
Default Different calc for lift between: force coefficient report and 6-DOF body force report
Norge
hxax is on a distinguished road
This is for a hydrofoil vessel. Lift coeff force report say 80 tons, 6-DOF body force report 90. About 10 ton difference. What is this?
hxax is offline   Reply With Quote
Old   January 15, 2020, 10:35
Matt
fluid23 is on a distinguished road
A lift coefficient report will not have units of tons. You will have to provide more info about your report setups if you want any useful feedback.
fluid23 is offline   Reply With Quote
Old   January 15, 2020, 20:21
Norge
well, the body mass lifted in DFBI is about ten tons higher than the lift capability predicted by the standard force coefficient reports.
Is the pressure somehow accounted for is some additional manner?
ton= N*E3/(9,81).
Old   January 16, 2020, 11:08
Matt
Since a force coefficient report doesn't directly indicate lift capability on its own, you have to make sure that your nondimensionalization parameters are appropriate. The coefficient report properties include reference values for pressure, density, velocity and area. If these aren't defined correctly then the force report and coefficient report will not agree. Likewise, if you are taking a coefficient and redimensionalizing it from a coefficient into a scalar value with units (i.e. N or lbf) then you need to make sure that the reference values used correspond to the coefficient assumptions. For that matter, also make sure that both reports include all the same surfaces/regions... it seems trivial but its easy to overlook the small stuff.
Now your second question is much more specific and probably a little easier to answer. I am not very familiar with 6DOF, but a quick read of the software documentation reveals a difference in the calculation of a force report and a 6DOF force report. Namely, it is the inclusion of user forces and gravity in 6DOF. A standard force report will only include pressure and shear forces.
That being said, it does sound like something is off. One wouldn't expect the inclusion of gravity to increase the net lift force.
I would suggest double checking your DFBI and report setups. Its impossible to troubleshoot without more info.
CFD Force Coefficient Report Error Urodele STAR-CCM+ 1 January 29, 2018 12:17
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Viscous force and coefficient viscous force tobino Main CFD Forum 0 February 20, 2011 22:06
