Design parameters to adjust the geometry
Old   January 13, 2020, 06:00
Default Design parameters to adjust the geometry
Nadine Lock
NadineLock is on a distinguished road
Hello everybody,
I have a few questions about design parameters to adjust the geometry:
  1. Can "Surface Mesh Parts" (green) be modified in geometry using "Freeform Surface Deformation"?
  2. Can design parameters from "CAD Parts" (blue), such as the diameter of a pipe, be changed within StarCCM+?
NadineLock is offline   Reply With Quote
Old   January 14, 2020, 04:56
akarfirath's Avatar
gago
akarfirath is on a distinguished road
Hello. As far as I know, If you want to create design parameter in STAR CCM+ you should do it in 3D-CAD module and you can not open a surface mesh parts in 3D-CAD. However if you have CAD parts it would work fine to create design parameters via selecting expose parameter command. Regarding the Free Surface Forming again you are able to do it in 3D-CAD module.
akarfirath is offline   Reply With Quote
Old   January 16, 2020, 02:10
Nadine Lock
ok thanks.
- How is it possible to change the dimensions of a CAD part (blue) that is opened with 3D CAD? As far as I've tried it, I could e.g. only carry out further extrusions etc., but do not change the existing block.
- Is there a way to edit surface mesh parts with free surface forming, e.g. after exporting the surface mesh part, editing with another program and then importing it?
Importing SOLIDWORKS geometry into ANSYS design modeler. Pegasos ANSYS 1 March 22, 2017 02:27
Infinity Jet Design Parameters geometrixeng Main CFD Forum 1 January 21, 2015 11:34
Real Geometry and input parameters of industrial boiler Michail Main CFD Forum 2 March 28, 2013 15:34
Design Modeler imported geometry natantyt ANSYS Meshing & Geometry 0 June 11, 2011 20:44
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 09:17
