January 10, 2020, 04:48 |
From surfaces to bodies
Emanuele
Rep Power: 6 |
Goodmorning everyone,
I am a newbie in the CFD analysis and a new user of Star CCM+ For my master thesis I have to study the aerodynamical performances of a car, and i imported it as an x_t file on the software but i can't convert sheed bodies to solid bodies; I have tried with extrustions, extended surface and many other ways including the surface wrapper (i have read the other thread with a similar problem with the boat, but that it didn't help me). Can't find any solution in Steve Portal too, someone could help me please? Here's a picture one of the many components i have to convert from sheet to solid Last edited by Prothean; January 10, 2020 at 17:24. Reason: Added an example |
January 12, 2020, 12:16 |
Rep Power: 25 |
Well for that particular part all you have to do is click on the green edges and select fill holes in the surface repair menu. I suggest you go through the surface repair tutorials.
January 12, 2020, 12:42 |
Emanuele
Rep Power: 6 |
Hi me3840 and thank you for your reply,
what i am really intended to do is to ad a little bit of thickness on the shoulder of my tyre, and the "fill holes" options would close the whole sides of the wheel |
January 12, 2020, 12:57 |
Rep Power: 25 |
If the geometry is drawn wrong then your best path forward is to go back to your CAD package and fix it.
January 13, 2020, 02:15 |
#5 | |
Remember the capabilities in this section are quite limited, so if you can go0d knowledge of CAD package, it is better to do it in there. |
January 13, 2020, 11:34 |
Emanuele
Rep Power: 6 |
I think it's better going back to my CAD software then, thanks everybody!
[ANSYS Meshing] ANSYS 2D Geometry/Meshing Plugin Error: Attach Failed, No Valid Bodies Found | cdase | ANSYS Meshing & Geometry | 0 | August 26, 2018 15:31 |
[DesignModeler] Find face normals to selected faces | Pallati | ANSYS Meshing & Geometry | 1 | July 26, 2017 12:04 |
NURBS surfaces on a wing | frossi | CFX | 5 | February 5, 2017 16:27 |
[Other] how to define complex/irregular bodies in the mesher | Ema40 | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2016 17:04 |
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 | s.mishra | ANSYS | 0 | March 31, 2012 05:12 |
