December 11, 2019, 10:22 |
total temperature
tuvia milshtein
Rep Power: 12 |
Hi everyone
How is the total temperature calculated in star-ccm ? thanks tuvia |
December 16, 2019, 00:15 |
Total temperature makes sense only for the flow with Mach>0.5. For in-compressible fluids as Gamma (Cp/Cv)m is 1, Total temperature equals static temperature
These are 2 formualtions used by Star-CCM for total temperature. total temp1.PNG total temp2.PNG Keep in mind that there use is conditional. Like second formulation holds true for isotropic conditions. |
December 16, 2019, 02:24 |
tuvia milshtein
Rep Power: 12 |
Thank you, Ashock. It helped
December 18, 2019, 15:29 |
tuvia milshtein
Rep Power: 12 |
Hi Ashock
I've noticed that even at high supersonic flow starccm uses the first formula Tt=Ts + v**2/2/Cp I'd like to use the second formula Tt=Ts*(1+(gamma-1)/2*Mach**) but I do not know how to insert the value of Gamma Do you have any idea ? |
December 19, 2019, 01:06 |
#5 | |
create a field function and put this definition. (${Temperature})*(1+(${Ma}*${Ma}*(1.4-1))/2) you can copy paste this directly. Change Gamma from 1.4 to your choice. For ${Ma}, You have to create mass flow average (or area average) report, rename it as Ma, select part/section and field function as mach number. Or else You can directly use Mach number filed function in field function definition, but I was getting some error, that is why I created report with Mach number definition. |
December 19, 2019, 01:29 |
tuvia milshtein
Rep Power: 12 |
Thank you Ashock
exporting relative total temperature from fluent to tecplot? | preetam69 | FLUENT | 0 | November 9, 2013 14:08 |
Unexpected large decrease in Total temperature across the shock using sonicFoam | JLight | OpenFOAM | 0 | December 16, 2010 12:46 |
Unexpected large decrease in Total temperature across the shock using sonicFoam | JLight | OpenFOAM Running, Solving & CFD | 0 | December 15, 2010 06:47 |
static temperature is higher than total temp. in buoyancy problem | amirbahador | FLUENT | 2 | October 24, 2010 08:21 |
Total pressure and temperature, isentropic | Chris | FLUENT | 0 | January 16, 2003 06:30 |
