Mesh Deformation not working when using Adjoint Solver
Old   November 11, 2019, 12:27
Default Mesh Deformation not working when using Adjoint Solver
ticotinr is on a distinguished road
Hello!
I am new to the adjoint solver, and am trying to optimize the mass flow rate through a vent on a car. Everything seems to be working, but when I run the mesh deformation, it only deforms the mesh by around 1e-6%, so essentially zero. I have been following the steps in the tutorial guide, and have gotten the tutorial case to work properly, but am unable to replicate it in my set-up.
I have the entire fluid domain set up as one region, and the vent as another region with interfaces at the inlet and outlet of the vent. I have my adjoint cost function tied to a mass flow report on the outlet interface of the vent. The adjoint solver is converging with the restarted GMRES method, surface sensitivity is calculated and is shown in an vector displayer. The region I want to deform is set to floating, but the mesh will just not deform. Could there be a common step I am missing?
Thank you!
ticotinr is offline   Reply With Quote
adjoint, aerodynamic, optimization
FFD shape deformation for 3D wing not changing the mesh lwc24 SU2 Shape Design 5 August 1, 2019 16:17
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
how to use adjoint solver mesh in next calc Steffen595 FLUENT 0 July 6, 2015 21:39
Adjoint Solver & Mesh Motion dancfd OpenFOAM Running, Solving & CFD 1 November 9, 2011 09:26
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
