Exploding Water Surface (VOF)
Old   October 10, 2019, 13:33
Default Exploding Water Surface (VOF)
Jakob Fischer
JackFischer is on a distinguished road
Hello there folks,
I've met my final enemy, my David to the great Goliath... but from the beginning:
I'm doing a wading Simulation, meaning I have a car, going in and through a water trench. To do so, I use the overset mesh method, meaning, that the moving car is located in its own meshed region. That region is moved by the motion specification "Morpher" along a given path. Same is applied for the tires, which are also rotating.
To the physics:
The water is initialized by the VOF-model, namely a flat wave with a given water depth. There is no current velocity given, as the water trench is closed to all sides, more like a pond.
I used both k-epsilon and k-omega turbulence models, 1st and 2nd order, with and without resolved boundary layer, wall function, no prism layers at all, all y+ treatment and so on.. basically any sensible combination of the given choices.
Timestep is a reasonable 1e-3s and in different fine mesh approaches I used between 5 to 15 million cells in a 1:1 modell.
But here it comes: after initializing and sucessfully running the simulation for some time something weird happens. Down the trench, far from any oversetmesh or boundary condition (appart from walls) the y+ values on the wall explodes at a (seemingly) random point. Veloty magnitudes reach skyrocketting levels, resiudals go through the roof and the water litterally shoots in all directions starting from said point. There is no change in mesh size, no velocity to deal with, no phase change, nothing.
I guess (at this point, anything is just an assumption ) the turbulence modells, whichever I'm using, is struggling with the fact, that it is stillstanding water. Because of this I dont know exactly, how I should build the mesh near the walls. Using k-e and trying to be in the log layer or a resolved boundary layer with the k-w model, I have zero velocity at the wall because of the stagnant water, giving no sensible value for the first layer.
If anyone has any tips, guesses or questions to be discussed, I'm happy to share details and learn about this. I'll try to upload some pictures tomorrow as well, it's kind of tricky though because of restrictions from my company..
Anyway, have a good one, and maybe we can solve this one (=
BTW: it's actually like the JLR approach, looking like the following:
JackFischer is offline   Reply With Quote
Old   October 10, 2019, 19:01
cwl
Chaotic Water
cwl is on a distinguished road
Morpher? - Why not just Translation Motion and Rotation for wheels relative to the wheel coordinate system?
It is advised for better stability to smoothen the initial Volume Fraction by few cells instead of setting sharp initial condition like
($$Position[2] <= 0.1) ?  1.0 : 0.0
Courant Number?
after initializing and sucessfully running the simulation for some time something weird happens .. the y+ values on the wall explodes at a (seemingly) random point
That's why we love multiphase - #$@s up in a random cell where everything is ok %>
Did you try playing with URFs? - Like setting Velocity and Volume Fraction to 0.1:0.9?
cwl is offline   Reply With Quote
Old   October 11, 2019, 02:49
Jakob Fischer
Thanks for your insights!
Because its not a static motion in one direction but the direction is changing. I have to add, without the mesh motion the stability seems quite ok...
Do I do this only in the initial conditions of the Pyhsics Continua or do I have to apply the same in all region physics?
Courant Number?
Thats another struggle, as stated above to find the correct wall distance with the water being at rest, the courant number tends to be zero.
I played with URF for velocity and pressure, but didnt notice that much of a difference in behaviour..
Old   October 11, 2019, 04:51
cwl
Chaotic Water
Sure you know your case better, but
1) does it diverge if you set just a Translation Motion?
2) UserGuide says:
In fluid mechanics applications, you can move the mesh rigidly according to prescribed rotations and translations (Rotation, Translation, Rotation and Translation, Trajectory motions), or use the Morphing method that accounts for non-rigid deformations.
Maybe try Trajectory after that?
Well .. if you do not set any Region-specific Initial Conditions - i.e. Initial Condition settings from Physics are applied to all Regions, then just set it in Physics only.
The idea, once again, is to smoothen the initial liquid-air interface.
Can't guarantee that it will help - but it's a good practice anyway.
Zero is ok where the liquid is still.
I meant more like maximum and average Courant number where motion of phases happens.
I'd say - in multiphase simulations Volume Fraction URF is the one affecting stability the most.
Old   October 11, 2019, 05:29
Jakob Fischer
2) UserGuide says:
Well I do not have any deformations becaus of the overset method, a mesh is moved through anoter mesh, being interpolated at the interface. I'd really like to stick with that approach, as I have exactly the movement I want and need. Dont know how to get to that with trajectory or any of the other.
I think I didnt get that right. In Physics -> Initial Conditions -> I have Volume Fraction -> Composite and put the equation you suggested in both phases. That produces an Error, I have to check my initial volume fractions in the regions, but no matter what I put in there doesnt work
Ok, but how would I calculate the first cell height with zero velocity? Is it iterative, check solution and change cell height accordingly? I'll check the solution and come back for the Courant numbers.
Alright, do you mean the URF under Segregated VOF -> Single Step?
Old   October 11, 2019, 05:47
cwl
Chaotic Water
What I mean is - usually initial conditions for Volume Fraction is set like two Field Functions:
$$InitialVolumeFractionofLiquid
$$InitialVolumeFractionofAir
($$Position[2] <= 0.1) ?  0.0 : 1.0
Which is discontinuous. What is recommended:
Wait, Courant number is:
Thus - it can be calculated in cells based on your velocity, mesh size and time step and show how "good" your time step is, since target CFL (Courant number) is adviced to be ≤ 1.
Given mesh cells sizes and given velocity distribution (driven by physics and process) - one can estimate a target time step.
Exactly. Try setting them to 0.1 and 0.9 .. might help.
Old   October 11, 2019, 06:14
Jakob Fischer
I really appreciate your help here!
I put these into the initial conditions for the physics contiuna, but no matter what I choose for the Volume fractions of the boundaries in the regions, the error "Please check your initial values for "Volume Fraction" in the following regions: ... " I seem to oversee something here..
So far so good, of course I know about the Courant number, how its calculated and that for certain turbulence models/boundary layer treatments it should be less than one. But what I'm struggling with, is the fact that I cant calculate it for zero velocity, can I?
morphing, overset, vof
Mass imbalance problem in multiphase water and steam CFX case Antech CFX 1 October 26, 2020 05:03
How to track water surface height in a VOF channel flow rjm1982 FLUENT 9 May 24, 2018 04:58
initialize open channel flow with a know water surface profile Ema40 Fluent Multiphase 4 February 21, 2016 12:31
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
swimming pool water surface motion due to wind J.Kim FLUENT 4 May 5, 2006 11:08
