August 25, 2019, 23:38 |
Field Function
Hi everybody, Previous I used ANSYS Fluent to simulate but now, I'm using Star CCM+ software to simulate for the HVAC project. because I just used this software in a few weeks. So I have a problem. I hope that everybody helps me.
I want to hook C language code (similar ANSYS Fluent) into STAR CCM+ to wind speed calculate. I don't know how to do. This is my code. Please help me. Can you help me how to create field function according to this formula My formula V2=3.7*log(z/0.6)/log(10.0/0.6) Thank you so much This my codel from fluent #include "udf.h" DEFINE_PROFILE(log_velocity,thread,index) { real y[ND_ND]; real z; face_t f; begin_f_loop(f,thread) { F_CENTROID(y,f,thread); z = y[1]; F_PROFILE(f,thread,index) = 3.7*log(z/0.6)/log(10.0/0.6); } end_f_loop(f,thread) } |
August 26, 2019, 06:55 |
Chaotic Water
Rep Power: 18 |
August 26, 2019, 11:21 |
Matt
Rep Power: 18 |
This should be easy. I haven't worked with Fluent much so forgive me if I miss something, but you should not need to do a loop to define this field function.
Simply go to tools and right click 'field functions' and select 'create new'. Rename it whatever you want and then set the definition as follows. Also, note that I am assuming this is a log 10 and not log e function you have defined. (For log e just use log() instead of log10(). 3.7*log10($$Position[2]/0.6)/log10(10/0.6) That should define that function at the centriod of each cell based on the z coordinate ($$Position[2]). |
August 26, 2019, 22:27 |
Thank you so much for your help. I was sending messenge on Skype to you
August 27, 2019, 01:18 |
#5 | |
Thank you so much for your help. But when I have imported your formula into STAR CCM+ I have met a problem " A Floating point exception has occurred: floating point exception {Invalid operation}. Thank you so much |
August 27, 2019, 06:07 |
Joern Beilke
Rep Power: 20 |
Just think a moment about the logarithmus of zero.
August 27, 2019, 12:06 |
#7 | |
Matt
Rep Power: 18 |
Also, as Joern pointed out. The equation you defined blows up (goes to negative infinity) when z=0. That is probably the source of your floating point error. If you are simply trying to apply a velocity profile to your boundary there are better ways to go about it. |
August 29, 2019, 08:05 |
#8 | |
Hello sir. If I can calculate my model based on the y coordinate. How to changed [2]? |
August 29, 2019, 08:13 |
#9 |
Matt
Rep Power: 18 |
The Cartesian coordinates are specified by the $$Position vector, where $$ denotes a vector quantity. X is $$Position[0], Y is $$Position[1] and Z is $$Position[2].
August 29, 2019, 21:53 |
#10 |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
problems after decomposing for running | alessio.nz | OpenFOAM | 7 | March 5, 2021 05:49 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 13:21 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 05:37 |
