Error while using 'free stream' in region settings
Old   August 21, 2019, 16:03
Default Error while using 'free stream' in region settings
Abhiijth
Kotabhi is on a distinguished road
I am new to this software and I am conducting velocity flow investigations on a bike surface.
When I changed the region type of the control volume block walls into ' free stream' and initialize the solution, I receive an an error saying that it is incompatible. The error vanishes when I change their type to wall. I don't not understand this issue.
I would be grateful if someone would explain this to me and let me know how if I want to continue with the ' free stream' setting.
Thank you.
Kotabhi is offline   Reply With Quote
Old   August 22, 2019, 10:44
Matt
fluid23 is on a distinguished road
Do you by chance have constant density model selected? I believe that it requires ideal gas law.
You might be better off with a velocity inlet and pressure outlet. There are several tutorials that are similar to this that you might find helpful.
fluid23 is offline   Reply With Quote
Old   August 22, 2019, 16:06
Abhiijth
Thank you. I will work on it and let you know. About the tutorials, I have searched on YouTube regarding star ccm+ but in vain. If you know some of them, I would be extremely grateful.
Old   August 22, 2019, 18:52
Sebastian Engel
bluebase will become famous soon enough
Hi Kotabhi,
usually StarCCM is installed with its manual (if you did not choose otherwise).
The manual contains a tutorial section. Just open StarCCM and click on "Tutorial Guide" in the "Help" menu.
You'll find some introductory information you should go through. You'll also find a section on incompressible flows.
However, sometimes there are some supplementary files necessary which might are only available via the costumer portal.
Best regards,
Sebastian
bluebase is offline   Reply With Quote
Can I use fvOptions to couple a solid region and a fluid region? titanchao OpenFOAM Running, Solving & CFD 4 January 14, 2022 08:55
How I can introduce my power heat (W) in chtMultiRegionFoam? aminem OpenFOAM Pre-Processing 32 August 29, 2019 03:23
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 06:07
Free Stream condition shah Main CFD Forum 1 January 10, 2007 14:58
Free Stream R Amini Main CFD Forum 1 May 2, 2002 06:16
