A floating point exception has occurred: floating point exception
Old   August 13, 2019, 15:56
Default A floating point exception has occurred: floating point exception
James
James38 is on a distinguished road
Hi everyone
I have tried running a simulation and encountered this problem after 236 iterations. I have tried every possible solution from the troubleshooting section on STAR-CCM+ User's guide, but it somehow didn't work. I just don't know what caused the problem. Could anyone tell me how to fix the problem, please?
**I have set under-relaxation factor as told in the user's guide = 3**
***My mesh properties: No. of Prism layers=25, Prism layer stretching=1.1, Prism thickness=2m, Core/Prism ratio=3***
Thank you
James38 is offline   Reply With Quote
Old   August 15, 2019, 07:58
Sebastian Engel
bluebase will become famous soon enough
Hi James,
your simulation is diverging. At some point the values become too large, and this floating point error is raised.
Could you give more detail on your simulation setup? What's your goal, what physics are you using, and what boundary conditions.
In case you cannot share such information. Especially check your boundary conditions.
You may also try to locate what quantity and at which location your simulation is likely to diverge. For that purpose have a look into your solver objects. You'll find an option called "Temporary Storage retained". Active this for your used solvers. This option makes intermediate quantities in additional field functions available, such as the spacial distribution of residuals.
Then check your domain where you get extreme values. This will allow you to check whether certain parts of the mesh are raising problems.
Best regards,
Sebastian
bluebase is offline   Reply With Quote
Old   August 15, 2019, 13:09
James
Thank you for your reply.
My goal of this is to get the correct y+ values as what I have now is too unrealistic.
For my physicals model and boundary conditions, you can see them in the attached images (if that's what you want to see).
*I have already activated the temporary storage retained option when I ran the simulation*
Thank you
Old   August 19, 2019, 05:22
tailele is on a distinguished road
Thank you
Sometimes is the mesh , try to do a mesh analisys
tailele is offline   Reply With Quote
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 12:43
A floating point exception - SEM Model yansheng STAR-CCM+ 1 April 4, 2016 05:57
Floating point exception from twoPhaseEulerFoam openfoammaofnepo OpenFOAM Running, Solving & CFD 1 March 19, 2016 14:56
[blockMesh] checkMesh Floating point exception error daniel.almeida OpenFOAM Meshing & Mesh Conversion 0 July 31, 2015 15:26
Floating point exception error with small DeltaT rassilon OpenFOAM Running, Solving & CFD 19 September 2, 2009 08:39
