Creating a set of inlet flow at different angles?
Old   August 11, 2019, 10:48
Default Creating a set of inlet flow at different angles?
James
James38 is on a distinguished road
Hi all
I know that we can change an angle of inlet flow direction, but I am wondering if it's possible to create a set of inlet flow direction at different angles and run it as one simulation without doing multiple times?
Thank you
James38 is offline   Reply With Quote
Old   September 9, 2019, 12:26
Ping
ping is on a distinguished road
you could create a field function that varies the angle as a function of iteration number or time for an unsteady run
but these days i would simply use design manager to run all the angles required
ping is offline   Reply With Quote
Inlet Boundary Condition for Open Channel type flow Akshay_11235 OpenFOAM Running, Solving & CFD 12 April 15, 2024 05:05
Reversed flow using pressure inlet and outlet? here_for_help FLUENT 0 September 28, 2018 16:20
How to set fully developed flow aty inlet? FernandoSoares OpenFOAM Running, Solving & CFD 7 November 18, 2016 01:16
Multiphase Flow BC-Mass Flow inlet not available? yimingchen.ok@gmail.com Siemens 1 July 18, 2014 07:08
How to set pulsating inlet boundary conditions with a very high frequency Ton CFX 10 March 22, 2012 17:57
