Directed mesh problem
Old   August 7, 2019, 17:13
Default Directed mesh problem
megi is on a distinguished road
Hi all,
I am new to STAR-CCM+ and trying to simulate flow around a surface-mounted cube. However, whenever I try directed meshing, the program gives the following error:
"Number of loops in guide cad surface ... is not equal to one. This implies that cad face could be missing a cad edge."
Does anyone know how to solve this problem?
Thanks.
megi is offline   Reply With Quote
Old   August 8, 2019, 00:22
me3840 is on a distinguished road
You cannot mesh that geometry as-is with the directed mesher. It works by sweeping a mesh on a face across a volume. No sweep is possible for your geometry because the cube is not swept across the guide (the vertical faces in your case).
If you want to directed mesh this you need to chop the volume into 3 pieces. First you must create a volume which is the volume occupied above the cube to the top face. Then slice the remaining large volume by the top face of the cube, making 2 volumes above and below that plane.
me3840 is offline   Reply With Quote
Old   August 8, 2019, 05:27
Hi me3840,
Thanks for the information. I will follow your suggestion.
Regards.
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 05:27
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 18:16
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[ICEM] ICEM Structured Mesh Problem OMJT ANSYS Meshing & Geometry 3 March 22, 2013 11:06
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
