Part body is not closed and manifold
Old   August 7, 2019, 06:59
Default Part body is not closed and manifold
Abhiijth
Kotabhi is on a distinguished road
I am working on a bike simulation and I am knew to CFD.
I have imported the bike through import surface mesh and when I want to perform subtract Boolean operation from a block, it shows the error 'part body is not closed and manifold'.
This error show even shows after looking into the surface repair tool and finding no pierced surfaces. I don't understand.
Help is greatly appreciated .
Regards,
Kotabhi
Kotabhi is offline   Reply With Quote
Old   August 7, 2019, 10:13
Matt
fluid23 is on a distinguished road
It sounds like a problem with your CAD model. You have to give more details in order for anyone to help you. Post an image or something to help us understand what you are starting from and where you are trying to go.
fluid23 is offline   Reply With Quote
Old   August 7, 2019, 10:28
Abhiijth
you can have a look into the CAD model. I have attached them. My purpose is to visualize the airflow, velocity, pressure scenes and shear stress on the surface.
Please let me know if you need more information. Help will be much appreciated .
Old   August 8, 2019, 01:22
Steve
steve lee is on a distinguished road
Yeah.. It looks that CAD have so many problems.
You have to redesign CAD model
First, you should make CV(Control volume for external flow)
Second, all surface should be closed (looks not closed surface many..)
Third, all surface shouldn't pierce each other
steve lee is offline   Reply With Quote
Old   August 8, 2019, 04:42
Default CAD Model
Abhiijth
Thank you.
I understand. However, they are no pierced edges when I tried to repair the model. There were a lot of free edges though. This error was the same after this step too.
Please let me know if there are any further or other ways to solve this problem.
beginner, star ccm+, surface mesh
[snappyHexMesh] Error: Feature line extraction is only valid on closed manifold surfaces? anu.raghun OpenFOAM Meshing & Mesh Conversion 6 December 20, 2023 02:14
Part Blade is not closed and manifold bmaldi STAR-CCM+ 5 May 26, 2019 21:49
source not closed and manifold error while performing boolean(subtract) operation rockydongre STAR-CCM+ 3 May 24, 2019 02:38
error:Part Prop is not closed and Manifold, Boolean subtract Vashishtha STAR-CCM+ 4 August 2, 2018 08:58
Source Region not closed and manifold. CaptainHarmony Main CFD Forum 0 June 28, 2017 13:23
