Negative Porous Coeffcients
Old   July 31, 2019, 17:06
Default Negative Porous Coeffcients
Bram
bram94 is on a distinguished road
Hello All,
With the help of this useful forum, I was able to do porous media simulations.
I've been trying to do more simulations. I got experimental data for a component. When I did a second-order polynomial curve fit (dP vs V) on this I got a negative inertial coefficient. It didn't really make physical sense to me. What would be some of the ways to check my data and get a better correlation, can I just use the absolute value of the inertial coefficient for my simulation? Thank you.
bram94 is offline   Reply With Quote
Old   August 6, 2019, 12:52
Matt
fluid23 is on a distinguished road
It is not unheard of to have this happen. It is a result of the shape of the test data you are fitting to and the fact that you have to force the y intercept to be zero. In a strict physical sense, you are correct.... it doesn't make sense for them to be negative.
However, from a numerical standpoint it shouldn't matter. The goal is to assign coefficients which deliver your experimental pressure drop. I have defined negative values before and got what I believed to be valid results back, so unless your simulation blows up you should be fine.
I wouldn't assign the absolute value of the coefficient, that will change the result of the function. Ask yourself this, is ax^2-bx = ax^2+bx? Only if b=0.
fluid23 is offline   Reply With Quote
Old   August 6, 2019, 12:55
Bram
That was a clear insight, thanks for the sharing it!
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
