July 25, 2019, 20:36 |
How to determine wind loads on a building?
James
Rep Power: 7 |
Hello everyone
I'm new to STAR-CCM, and wondering if I can calculate wind side loads on a building? I'm currently working on analysing wind flows around the building and want to find out side-loading pressures acting on the building. Thank you |
July 26, 2019, 03:32 |
#2 | |
You can do this in STAR-CCM. Create a case with flow around building. You will know the pressure profile on building surface. From areal elements you may be able to calculate resultant force on the building as well as the whole force profile like force distribution, center on action etc. |
July 27, 2019, 19:07 |
James
Rep Power: 7 |
How do I create a case? I'm sorry, I just have no idea how to do it. Do I have to create a new field function?
July 28, 2019, 14:15 |
Rep Power: 24 |
By case ashokac7 just means a simulation. If you are not sure how to create force reports there's at least 1 tutorial that covers this, I would suggest you look at the tutorial guide.
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." | lethu | OpenFOAM Meshing & Mesh Conversion | 1 | June 3, 2020 07:49 |
[foam-extend.org] Error compiling OpenFOAM-1.6-ext | Canesin | OpenFOAM Installation | 137 | January 20, 2016 14:56 |
Wind on building simulation | cedrik | OpenFOAM Running, Solving & CFD | 14 | December 17, 2014 04:21 |
wind tunnel results for building pressures | danijela.djuric.mijovic | Main CFD Forum | 0 | April 4, 2014 09:50 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
