July 23, 2019, 07:32 |
Heat transfer coefficient
Rep Power: 7 |
I’m working in a heat sink model. I’m trying to validate my results with an experiment results. I applied a heat source at the bottom of the heat sink and then i used the surface average to get the heat transfer coefficient at the surface of the heat sink. I got almost 350% which is not acceptable I don’t know why. My first question is do we consider the bottom of the heat sink ( where the heat source applied) when getting the heat transfer coefficient? Because I didn’t consider it I just considered the other sides.
July 24, 2019, 23:07 |
Rep Power: 24 |
Write down the equation for heat transfer coefficient and try to compute it using the face getting heat input on the heatsink. Is there anything missing that prevents you from calculating it?
July 25, 2019, 06:12 |
Rep Power: 7 |
@me3840 I got the boundary heat flux of the heat sink (whole geometry) over the temperature difference is this way right to get the heat transfer coefficient?.
July 28, 2019, 16:50 |
Rep Power: 24 |
Yes, that would be correct.
Interphase mass transfer of a reaction | cfx_ws1992 | Main CFD Forum | 0 | May 15, 2017 21:42 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade | Karkoura | CFX | 0 | March 10, 2011 15:35 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
