Divergence of Energy, momentum and continuity
Old   July 9, 2019, 00:51
Default Divergence of Energy, momentum and continuity
Ian
cgswjs is on a distinguished road
Hi guys,
I'm new to star ccm+ and I'm doing a project about a double pipe heat exchanger with turbulators in the annulus region. I've got the mesh and deleted bad cells. Boundary conditions are velocity inlet and pressure outlet for inner pipe fluid region, mass flow inlet and pressure outlet for annulus fluid region. I've been trying to run the simulation with different sets of meshing and they all have this Bi-conjugated not diverge error. The spike always shows up around 60th step. Can someone help me with this problem? I don't know where to start to fix this. Btw, I used K-E turbulence model for the annulus flow.
cgswjs is offline   Reply With Quote
Old   July 9, 2019, 01:07
me3840 is on a distinguished road
Originally Posted by cgswjs View Post
Hi guys,
This is generally not a good sign. Have you inspected your mesh quality? Please post images of your mesh.
If you look at the blown up solution your should be able to see where velocities and temperatures are very high, which will point to the problem.
me3840 is offline   Reply With Quote
How to use PIMPLE properly? floquation OpenFOAM Running, Solving & CFD 27 August 12, 2024 11:15
Implicit divergence operator for continuity equation t.teschner OpenFOAM Programming & Development 4 December 29, 2022 14:31
Continuity divergence in simple gas flow Okka FLUENT 7 January 11, 2019 02:01
How to obtain values of Energy, Continuity and X, Y, Z Momentum in StarCCM+ hassanmoin STAR-CCM+ 5 May 23, 2018 00:35
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 23:29
