June 10, 2019, 13:42 |
Importing Plot 3d Mesh
Pierce
Rep Power: 7 |
I'm trying to import the mesh of the Onera M6 wing from the following NASA website https://www.grc.nasa.gov/WWW/wind/va.../m6wing01.html The author states that the m6wing.x.fmt is in plot3d format, however the .x.fmt part is not one of the file types that can be imported. It is later mentioned that this is converted into a run.cgd file however this cannot be imported either. Any clarification or direction would be appreciated. Thank you. I saw that changing file type from .x.fmt to .x allowed import to work. Last edited by PierceH; June 10, 2019 at 14:17. Reason: FIX |
Mesh Changing When Importing from Fluent | russel60 | OpenFOAM Running, Solving & CFD | 0 | February 15, 2019 17:43 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 05:17 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 08:05 |
