Part Blade is not closed and manifold
Old   May 23, 2019, 04:09
Default Part Blade is not closed and manifold
Aldias Bahatmaka
bmaldi is on a distinguished road
Hello guys,
I need some help from you, if anyone know how to solve the problem, I'll appreciate.
Here is I Attach the figure's problem
Best regards,
Aldi
bmaldi is offline   Reply With Quote
Old   May 23, 2019, 04:27
Steve
steve lee is on a distinguished road
Hi, the file you attached has some problem..
try to do repair surface
steve lee is offline   Reply With Quote
Old   May 23, 2019, 05:06
Aldias Bahatmaka
Hello Mr.Steve,
Thanks for replying,
Yes the file can't be opened,
The comment says:
"Started default macro:
C:\Users\1012534\AppData\Local\CD-adapco\STAR-CCM+ 13.04.010\var\journal\star6644818832237917339.java
Loading module: StarMeshing
Loading module: MeshingSurfaceRepair
Creating one part per imported file.
Reading surface from .stl file: Blade.stl
Scaling from model units: meter
Done importing surface: CPU Time: 0.98, Wall Time: 0.98, Memory: 94.94 MB
Imported surface statistics:
# Faces: 109870
# Vertices: 54940
# Special Edges: 0
Reading surface from .stl file: Hub.stl
Done importing surface: CPU Time: 0.00, Wall Time: 0.00, Memory: 95.20 MB
# Faces: 196
# Vertices: 100
# Special Edges: 0
Part Blade is not closed and manifold.
Command: ExecuteMeshOperation
error: Server Error"
I tried to do some repair surface but in other tool (3D CAD Model), it seems like the model should be solid, but I'm not sure.
Do you have any reference to repair model inside of Star CCM+ CAD model?
and I have another question,
Do you know if the problem related the interface (Between rotating and static domain)?
Thanks before,
regards,
Aldias
Old   May 23, 2019, 05:23
Steve
you mentioned '.stl' So it is not kind of solid data..
it is just node data..
yes i tried many case of MRF simulation and multi region simulation..
hm.. so you made 2 region ? or just 1 region with error?
as i understand you can not make a mesh because your second file has some geometrical problem.
you shuld fix first.
Old   May 23, 2019, 21:29
Aldias Bahatmaka
Dear Mr.Steve,
Thanks for the reply,
So it means that the stl file can't be boolean substract operated right? How if .igs file?
for my simulation, I made 2 boundary domain, static domain and rotate domain, but when the mesh process, it was stopped because of error of interface in rotating domain.
and error says:
"surface is self intersecting
command: ExecuteAutoMeshOpertaion
Do you know how to solve this?
Thanks a lot,
regards,
Aldi
Old   May 26, 2019, 21:49
Steve
You can boolean your domains even though the file type is stl.
First, check your each domain that has ay kind of surface problem..
when you check surface problem, you should show 1 volume (check 2 times)
Second, you should make 2 mesh continua.
Third, you should match each mesh continua and region.
try again! I think 2 kind of problem you may have
1. surface error
2. mesh continua matching
also it is possible that : 'domain settng problem'
if your rotating region is belong to main region.
you have to rid of the the rotating region in main region
source not closed and manifold error while performing boolean(subtract) operation rockydongre STAR-CCM+ 3 May 24, 2019 02:38
error:Part Prop is not closed and Manifold, Boolean subtract Vashishtha STAR-CCM+ 4 August 2, 2018 08:58
Source Region not closed and manifold. CaptainHarmony Main CFD Forum 0 June 28, 2017 13:23
Transient simulation of intake manifold Santoshnalanagula FLUENT 0 January 1, 2014 08:32
Automotive intake manifold CFD modeling with resonance. DBFIU Main CFD Forum 0 January 2, 2012 14:14
