Axisymmetric supersonic conical flow
Old   May 8, 2019, 06:27
Default Axisymmetric supersonic conical flow
users is on a distinguished road
Hi
I am trying to model the simple case of axisymmetric flow over a cone but I can't seem to get it to converge. My models are axisymmetric, ideal gas, coupled flow, spalart-allmaras turbulence.
My mesh is:
The bottom is an axis, the left is velocity inlet, the right is pressure outlet and top is freestream. I have tried a lot of different models and meshes and nothing seems to work. If anyone has tips/advice I would appreciate it.
Thanks in advance
users is offline   Reply With Quote
Old   May 8, 2019, 17:56
Matt
fluid23 is on a distinguished road
Have you tried mesh refinement to resolve the shock(s)? Just looking at your mesh, it looks like the steep gradients associated with the shock would not jive with the large cell size in the core flow (away from the body).
fluid23 is offline   Reply With Quote
Old   May 10, 2019, 04:54
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
What you could try is using a ramp for the prescribed flow quantities at the boundaries. E.g. if you prescribe a velocity of 1000 m/s at the inlet then ramp it up over a few iterations. Define a field function like this and use it as the inlet velocity
((${Iteration} < 500) ? (${Iteration}/500.0) * 1000.0 : 1000.0 )
This will ramp up the velocity linearly over 500 iterations. Just an example, I have no idea how many iterations might be needed to get your particular case to run.
Btw: you probably don't need the mesh refinement at the boundaries left, top and right.
What is your Mach number exactly? The mesh refinement region seems to be suitable only for very high Mach numbers, i.e. flows with a very narrow Mach cone.
flotus1 is offline   Reply With Quote
Old   October 16, 2019, 16:34
P
macaroni is on a distinguished road
Originally Posted by users View Post
Hi
My mesh is:
Attachment 69859
Thanks in advance
Do you have code for axisymmetric nozzle? Python or matlab?
macaroni is offline   Reply With Quote
axisymmetric, cone, conical, supersonic
Injection of gas into tube with small holes - Supersonic flow mrsl Main CFD Forum 0 December 5, 2018 07:49
steady compressible axisymmetric isothermal flow of Newtonian fluid in conical tube Ivanjica Main CFD Forum 0 January 11, 2018 16:34
Supersonic Inlet for a Compressible Flow in a Nozzle Daco FLUENT 8 November 8, 2012 04:34
Turning supersonic flow into subsonic Salexv FLUENT 7 September 23, 2012 21:10
supersonic axisymmetric cavity flow jsinha1987 FLUENT 0 August 21, 2012 12:11
