Preconditioned Conjugate-Gradient has stopped! / Matrix may not be Symmetric Positive |
April 6, 2019, 10:28 |
Rep Power: 7 |
Hello everyone!
I have a problem with my CFD simulation in STAR-CCM+ 13.02. I'm trying to run simple CHT Fluid-Solid simulation, which I have ran many times already (Steady state, k-w SST). This time, after implementing my next variation of the geometry some problem has occured and I cannot run simulation properly. Before the start of iterating output shows: Conjugate-Gradient Solver did not converge ! ** Preconditioned Conjugate-Gradient has stopped!** ** Matrix may not be Symmetric Positive Definite** Warning: non-diagonally-dominant rows, rows#=1573 After the 1st iteration, Sdr residual goes crazy up to e^8, then after couple of next iterations, the rest of residuals join Sdr.. I have seen 1st line of the error message many times and nothing wrong happened, however I have never seen next lines before. Do you know guys, what might be wrong? |
April 9, 2019, 04:20 |
Steve
Rep Power: 8 |
I had the same experience with your problem.
My problem was mesh quaility. I wonder that is there any thin mesh in your geometry? or what type of mesh do you use near interface wall? poly? or trim? |
April 9, 2019, 07:31 |
Rep Power: 7 |
I have solved my problem today. My geometry was lacking one of crucial holes, fluid couldn't flow.. I'm using full trimmed mesh.
matrix diagonal dominance |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 15:42 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 06:35 |
OpenFOAM version 1.6 details | lakeat | OpenFOAM Running, Solving & CFD | 42 | August 26, 2009 22:47 |
Preconditioned Conjugate Gradient Solver! | Chidu | Main CFD Forum | 1 | January 21, 2004 12:43 |
Block Matrix Solver Using Conjugate Gradient | John | Main CFD Forum | 2 | July 31, 2001 13:08 |
