Combine part surfaces if along a specified plane |
March 26, 2019, 09:44 |
Rep Power: 10 |
My imported CAD geometry is a complex shape. The imported parasolid file results in a single body/part with a single surface. I have split the surface into multiple surfaces (60 surfaces) using split by part curves (same result with split by angle). Now, I need help combining the 60 surfaces into 5 surfaces to more easily define 'create a boundary for each part surface'. My goal is to not use the GUI to select the surfaces. Do you have any ideas? Is there a way to combine a set of surfaces that lie along a specified plane? Thanks for your time, Mirage |
March 26, 2019, 19:43 |
Rep Power: 25 |
Sure, you can write a Java macro which uses a set of reports or the surface repair queries to identify the bounding box/barycenter of each surface, then combine them accordingly. That can be done entirely in batch with no user input.
Intersecting Part Surfaces Problem | mistergiggle | STAR-CCM+ | 1 | December 3, 2018 17:39 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
[swak4Foam] run-time function/expression evaluation at a part of a cross section | silvan | OpenFOAM Community Contributions | 3 | August 3, 2015 11:12 |
Combine non rotating part with rotating parts or not ? | teck0516 | Main CFD Forum | 0 | July 16, 2011 14:38 |
Meshing a Mixing Plane in ICEM | Will Anderson | ANSYS Meshing & Geometry | 2 | November 9, 2010 10:16 |
