March 14, 2019, 07:44 |
Particle tracks disappear
Rep Power: 7 |
Hey,
me and some friends are currently writing our bachelor. Here we are simulating a cyclone seperator with dust and air in STAR CCM+. We are using euler-lagrangian and RSM. We get the results we want with the pressure drop. But when im trying to see the particle tracks of the lagrangian phase, they stop before they have reached the outlet. If i change the lagrangian phase to gas and 1.205kg/m3 instead of solid with 3320kg/m3 i get the particle tracks to work. The particles have a diameter of 5*10^-6m and the inlet speed is 20m/s. Im trying to figure out why they are not getting tracked. Look at the image. Anyone know how to fix this? https://imgur.com/z6rP8ft We are using this article as a guideline: https://dokumen.tips/documents/cfd-v...-star-ccm.html In advance, thanks for the help |
March 14, 2019, 18:11 |
Chaotic Water
Rep Power: 18 |
Solvers -> Lagrangian Multiphase -> Steady -> Max Residense Time
Solvers -> Lagrangian Multiphase -> Steady -> Maximum Sub-Steps |
March 19, 2019, 06:26 |
Thanks for the reply
Rep Power: 7 |
Thanks for the reply cwl. I tried it, but it did not work. But after alot of fail simulations i figured it out. I had to change the wall to rebound, that did the trick. Now the simulation is complete and the results are quite good.
March 19, 2019, 06:29 |
Chaotic Water
Rep Power: 18 |
Oh, that's great. Although - that's strange, because the default wall-particle setting is rebound.
March 19, 2019, 07:24 |
Strange
Rep Power: 7 |
Yeah we thought it was strange as well, we did also think it was default. Glad the problem is fixed tho, dont know if it has much to say but we are simulating in unsteady..
Currently im trying to figure out the boundary sampling, the tutorial in star ccm+ is not to good. i manage to get a sum report of the time at the different outlets with "solid @ seperator: outlet" but the particle count has no data. Got any tricks for this? Thanks cwl. |
March 19, 2019, 07:57 |
Chaotic Water
Rep Power: 18 |
Try Phase Mass Flow Report?
March 19, 2019, 08:47 |
Thanks
Rep Power: 7 |
That worked alot better! Thanks alot for the help. Appreciate it cwl!
particle tracking |
Displaying of unsteady particle tracks | Malthehh | FLUENT | 0 | October 12, 2017 09:12 |
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 17:30 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 02:30 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 02:29 |
Particle Tracks | Anand | Siemens | 2 | October 10, 2005 14:38 |
