anonymus
Rep Power: 10 ![]() |
I am modelling a porous medium in starccm. in order to determine the inertial and viscous coefficients of the i have plotted a velocity vs pressure drop curve and get an equation like dp=av+bv2. I van calculate the values of 1/alpha and C2. as 1/alpha=a/(Dynamic Viscossity) and C=(2*b)/Rho Now how i could determine the values of Pi and Pv. |
carno
Rep Power: 17 ![]() |
Write your equation in the form,
deltaP/L = Pi*V2+Pv*V, You will get the values. Where, substrate length (L) Pressure drop (deltaP) porous inertial and viscous resistance (Pi; Pv) and velocity (V) |
#3 | |
anonymus
when I fit my equation on the curve I get DP=312.72v2+2.7232V which makes Pi=312.72 and Pv=2.7232 is length of substrate equals to the length of porous medium. Additionally, I was looking for different examples in the text they always qoute Pi < Pv. even in the starccm tutorial Pi<Pv. than how this will work. |
Matt
Rep Power: 18 ![]() |
Make sure your units are consistent, too. Use Pa and m/s or psf and ft/s. I suggest doing a dimensional analysis and working out the units so you make sure that what you are inputting agrees with the input units in star/ccm.
Pi and Pv really can depend on the shape of the DP curve so it is possible that you have low Pv. However, in my experience Pv is usually the larger of the two. |
#5 | |
anonymus
I am sure about "a" that its unit will be (pascal/m/sec) but can you please confirm the units of "b" Additionally for a second order polynomial your b will be always higher than a. therefore I am confused. |
Matt
you might have a/b and Pi/Pv swapped and your units for 'a' are wrong. Consider it this way:
dp/l = Pi * V^2 + Pv * V or y = a * x^2 + b * x Where y=dp/l, a = Pi, b = Pv and x = V The units of a * x^2 and the units of b* x must be the same as dp/l (i.e Pa/m). Therefore, the units of a or Pi must be Pa-s^2/m^3 and the units of b or Pv must be Pa-s/m^2. (Pa - s^2 / m^3) * (m^2 / s^2) = Pa / m (Pa - s / m^2) * (m / s) = Pa /m These actually simplify further into kg/m^4 and kg/m^3-s respectively. If you are using SI units in your file, then these are the preferred default units for inertial and viscous resistance. |
inertial coefficient, porous body |
Porous Medium: Obtaining D/F coefficients from Pressure-Drop Experiment | sdfij6354 | OpenFOAM Running, Solving & CFD | 11 | November 22, 2023 17:33 |
UDF for Sorption in Species Transport through Porous Medium | Kosch | Fluent UDF and Scheme Programming | 6 | October 21, 2020 17:46 |
Viscous resistance coefficients in porous medium | fpingqian | FLUENT | 50 | June 26, 2019 01:55 |
Velocity inlet boundary condition for porous medium | Chander | CFX | 3 | March 11, 2012 21:18 |
porous medium and reactions | Valeria | FLUENT | 1 | July 10, 2009 03:58 |
