Surface Wrapper Problem
Old   January 7, 2019, 14:10
Default Surface Wrapper Problem
Kamui is on a distinguished road
Hi everybody,
I have a question regarding the surface wrapper: when I try to perform my mesh, I receive this error:
Error during surface wrapping, deleting resulting mesh
a facetype may belong to only one wrapper subgroup
Command: GenerateSurfaceMesh
Recoverability: Non-recoverable
Does anyone know how to fix this problem?
Thank you so much.
Kamui is offline   Reply With Quote
Old   January 7, 2019, 19:41
me3840 is on a distinguished road
This is a bug. I would suggest you just try and change some of the wrapper settings so that the situation that brings it about doesn't occur.
It's also a good idea to make sure all of your wrapper settings make sense.
me3840 is offline   Reply With Quote
Old   January 28, 2019, 11:12
Owen
SoAero is on a distinguished road
This points to multiple part surfaces which contain the same patch id -- which is not allowed. So this is maybe an input error. Where did you get the surface that you're trying to wrap? What version of STAR-CCM+ are you using?
I know the error message is not helpful. I'd suggest going into surface repair and trying to find that or those surfaces and doing some reorganization. Maybe make a new part surface and add those duplicated ids to a new part surface.
SoAero is offline   Reply With Quote
Old   January 28, 2019, 12:58
I'm using starccm 13.06.12.
I found a salution of the problem. I just did some changes of my .prt file and now it seems that it works. Thank you for the help.
Urgent Help: Surface Wrapper & Contact Prevention (Crashes using more than one CP) AndreP STAR-CCM+ 7 August 2, 2018 08:04
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
Problem with surface tension luc.gig Fluent Multiphase 0 March 7, 2014 08:53
Catalyst Modelling Boundary Problem (Surface reaction) Fritz STAR-CCM+ 0 August 6, 2013 10:10
surface orentation problem in icemcfd jeevan kumar CFX 0 August 18, 2008 05:25
