Error while importing surface mesh
Old   December 16, 2018, 09:25
Question Error while importing surface mesh
Roozbeh Shahvelayati
R.Velayati is on a distinguished road
Hi Everyone!
I'm trying to Model a wind turbine in STAR CCM+. I used Rhino for generating the geometry and now I want to import it in STAR but every time I try I receive Error which says an Error occurred and the result log is just created but the log file is also empty. I used all .3dm, .igs , . stp , . x_t formats but no one work for me. I checked the geometry several times and I don't think that it's the problem.
I'm pretty confused. I'll be very glad to hear your advice.
thanks so much.
R.Velayati is offline   Reply With Quote
Old   December 16, 2018, 14:05
Ga
lightning0 is on a distinguished road
Since you're using rhino I assume you have solidworks. Can you open the native rhino file in solidworks? Try doing that then exporting to .stp/igs/x_t inside solidworks
Another option would be to import the .stp file into solidworks and check the body for errors. This has helped me before.
If you don't have solidworks maybe try something like MeshLab, I have little experience using it so maybe someone else can help
lightning0 is offline   Reply With Quote
import cad, surface mesh
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 16:15
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 19:48
