Intersecting Part Surfaces Problem
Old   November 30, 2018, 18:44
Unhappy Intersecting Part Surfaces Problem
Oliver Groenbaek
mistergiggle is on a distinguished road
Hello all,
Hopefully there is a straight forward solution. I have attached 2 images, the first displaying the part surfaces in question, the second identifying the intersecting part surface.
My problem is that when I try to mesh, I get an error that there is a 'self intersecting part' which I have identified as the surface shown in the attached image. As a result I am unable to run an automated mesh.
I tried deleting the part surface (925) that is bugging me and it would run a mesh, but I get an error message that says 'surface not closed'.
And this too is a problem, because I do get a 'problem indicator' on the automated mesh, yet I can view a mesh scene. However because of it, I am unable to run a simulation because there is no valid volume mesh.
Any suggestions?
Cheers,
Oliver
mistergiggle is offline   Reply With Quote
Old   December 3, 2018, 17:39
PK
pavko718 is on a distinguished road
It's difficult to tell from just your screenshots, but it looks like you need to imprint the offending patch to the larger surface beneath it (in the second picture) and then either delete the imprinted area or turn it into a baffle. Alternately, you can give that patch a small offset to bring it out of contact. It really depends on the topology. If you are meshing a fluid volume around the airfoil shape, offsetting will result in the mesher attempting to fill the tiny gap with cells, and is not what you want.
pavko718 is offline   Reply With Quote
Error Messages: Self intersecting faces, Solid Part is not closed, Floating point. bigtoasty STAR-CCM+ 1 March 4, 2016 06:05
[snappyHexMesh] Snapping problem, non orthogonal faces Zephiro88 OpenFOAM Meshing & Mesh Conversion 7 April 17, 2015 03:56
[ICEM] Problem while improting Solidworks Part file or Acis File into ICEM CFD venki1130 ANSYS Meshing & Geometry 0 October 13, 2011 14:04
[ICEM] [Student] Problem: Nodes Merging FALCON_SR71 ANSYS Meshing & Geometry 8 March 21, 2010 06:47
Multiple Sahdows / Periodicity Problem Michael Pi FLUENT 0 July 11, 2005 08:42
