Tumble calculation Ricardo Formula (Angular Moment Flux)
Old   November 20, 2018, 11:24
Default Tumble calculation Ricardo Formula (Angular Moment Flux)
Andrea
andreadepa is on a distinguished road
Hello, I'm doing a steady flow simulation of a flow bench and I'm trying to calculate the Tumble Number with the Ricardo Formula
(8*Moment)/(Massflow*Bore*Isentropic_Velocity).
I'm having some trouble in calculating the Moment in my simulation in order to compute the Tumble number.
I have created a volume threshold in order to calculate the Moment in a specific region with a local Coordinate system (Tumble_cs) and I've calculated the angular momentum (Kg*m^2/s), with the following field function:
${Density}*${Volume}*($${Centroid}(@CoordinateSyst em("Tumble_cs"))[0]*$${Velocity}(@CoordinateSystem("Tumble_cs"))[1] -$${Centroid}(@CoordinateSystem("Tumble_cs"))[1]*$${Velocity}(@CoordinateSystem("Tumble_cs"))[0])
I've created a sum report of this field function computed in the threshold I was talking before.
By far I know that it could be possible to obtain the Moment in this region if I could compute the Angular momentum flux (Kg*m^2/s^2 = Nm).
Thanks in advance for the help
andreadepa is offline   Reply With Quote
angular, flux, moment, ricardo, tumble
Tumble calculation pary07 STAR-CCM+ 8 March 28, 2020 21:01
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Angular momentum flux through faceZone askjak OpenFOAM Programming & Development 1 March 5, 2010 15:42
flux formula & error distributions student Main CFD Forum 1 February 8, 2005 06:42
the calculation of convective flux Hai-Wen Ge Main CFD Forum 14 April 23, 2001 07:34
