Supersonic wind tunnel- floating point error, overflow |
Rep Power: 0 ![]() |
I am modelling a supersonic wind tunnel to simulate shock trains and measure the axial pressure distribution. When using a coarse mesh, the simulations converge. However, as it becomes more refined I get a floating point error: overflow. I have tried using temporary storage retained and running it for one iteration to check for convergence, but as soon as it is refined enough the error returns.
Rep Power: 24 ![]() |
Please post images of your case and list the BCs you're using.
Are you using the coupled solver's grid sequencing initialization? |
The boundaries are set as stagnation inlet and pressure outlet, relative to atmospheric pressure.
I am unfamiliar with grid sequencing initialisation but will look into this and try it out, thank you! |
convergence, floating point, overflow |
icoFoam - Floating point exception (core dumped) | File | OpenFOAM Running, Solving & CFD | 26 | March 6, 2021 04:26 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
Floating point error and divergence detected | aannjj | FLUENT | 0 | July 2, 2013 03:44 |
defining velocity profile in a wind tunnel model | Erdem | FLUENT | 0 | June 20, 2006 13:00 |
Wind Tunnel Experiment Validation | zi | FLUENT | 1 | August 5, 2005 18:19 |
