October 17, 2018, 13:11 |
Flow over 4 airfoils in STAR-CCM+ -2D case
JOHN SHERJY SYRIAC
Rep Power: 8 |
Hi
I am trying to simulate flow over 4 airfoil one kept in the wake of another airfoil in 2D case. Rectangular domain is taken as the flow domain with K-omega model with polyhedral mesh. Chord length c= 0.605m Top and bottom surface = 5c -(symmetry plane) inlet velocity =109 m/s outlet = Pressure outlet I am not able to get the predicted flow output. After some time, there is zero velocity zones in the domain. I have no clue why is it happening. It would be grateful if anyone could help me figure out the problem. I hereby attach the velocity scalar scene of the flow. Thank you in advance |
October 17, 2018, 14:42 |
Matt
Rep Power: 18 |
How many iterations? What do your residuals look like? How are you initializing the solution?
You need to provide more info. |
October 19, 2018, 00:09 |
JOHN SHERJY SYRIAC
Rep Power: 8 |
time step = 7.989*10^-5
the problem happens after around 0.5sec the residuals converge upto less than 10^-4 |
airfoil 2d, star-ccm+ |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 16:13 |
'2-phase' gas-liquid flow validation on this case. | Ash Kot | FLUENT | 0 | June 1, 2017 19:25 |
2 phase flow validation on this case. | Ash Kot | Fluent Multiphase | 0 | May 31, 2017 04:11 |
Setting up a case for a plane plate in a longitudinal flow | Chronique | OpenFOAM Running, Solving & CFD | 0 | October 9, 2014 15:17 |
