Thermosyphon
Old   October 17, 2018, 11:37
Default Thermosyphon
Abdul
arehman1289 is on a distinguished road
Im trying to simulate a U-shaped thermosyphon based on this procedure but in starccm+ and with an outer copper casing.
https://www.youtube.com/watch?v=hPeGvczYHMM
In short I have done the following.
1. Three part geometry, of outer copper tube, inner water and air. The inner geometry is divided into two since I want to initialise both regions differently, with air and water.
2. Used the Eulerian multiphase VOF model with multi-component liquid - water as phase 1. Phase 2 was a multi-component gas with air and water vapor.
3. I enable the evaporation/condensation model and link h20 water with that of vapor.
4. I initialise the air region of the geometry with 1.0 mass fraction of air and 0.0 of the others and similarly for the water region.
However I get the error that sum of mass fractions is zero. I dont know why this is happening. If I put random non-zero values, the simulation runs but crashes immediately with AMG solver non-convergence.
Any tips ?
Thank you.
arehman1289 is offline   Reply With Quote
Condensation in a closed thermosyphon??? (heat pipe, evaporation-condensation)) xiaobingwill FLUENT 9 December 21, 2016 12:25
Need advice and/or tutorials for Fluent VOF method two phase closed thermosyphon flow ic3lemon Fluent Multiphase 1 November 6, 2016 08:34
Multiphase - Thermosyphon rudolfkhalil FLUENT 2 November 6, 2016 08:29
VOF method in fluent for two phase thermosyphon flow ic3lemon Fluent Multiphase 1 November 1, 2016 05:40
help needed on Design and Analysis of thermosyphon solar water heater simran46 ANSYS 1 July 9, 2014 14:19
