October 1, 2018, 17:57 |
Dual stream heat exchanger
Matteo Rosellini
Hi everybody! It's my first time in the forum, even if i read very often your adviceses. I'm trying to do a dual stream heat exchanger simulation with the radiator that we use on our FSAE car. I'm following the star ccm+ tutorial "dual stream heat exchanger" but i have problems meshing my geometry. I modeled with solidworks the radiator, the "coolant top" and the "coolant base" that we can see in the picture and i did an imprint operation to generate the physic contact between radiator top face and coolant top/base base faces, then i assigned parts to region and i set the interfaces. The surface mesh runs, but when i try to generate the volume mesh i have an error saying "edge attached to an odd number of faces" and visualising in "representation" the remeshed surface i have the free edges that are showed in the picture:
How can i fix this error? Thank you in advance |
October 3, 2018, 10:24 |
#2 | |
Your picture is not visible. But from what I understand, You have non-manifold edges error. Check in surface repair that where you are getting these edges/faces. You can try to repair it there itself or go back to CAD to get good surface. Hope this helps. |
dual stream, edges, imprint, odd faces |
Double pipe heat exchanger | mohcin | FLUENT | 21 | June 18, 2016 15:19 |
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent | medogalal | FLUENT | 3 | December 30, 2015 05:28 |
Modelling serpentine heat exchanger | andbe | ANSYS | 0 | September 30, 2013 10:08 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 7, 2008 00:17 |
