2D Axisymmetric simulation with morphing boundary
Old   September 6, 2018, 14:37
Default 2D Axisymmetric simulation with morphing boundary
JM27 is on a distinguished road
Hi there, I am hoping to get some help on 2d axisymmetric simulation in ccm+. Been stuck on this for a few days now so any suggestions would be appreciated...
I am trying to run a 2d axisymmetric simulation with moving boundary using the mesh morpher solver. My set up involves a square domain with the right boundary set as the axis of symmetry. The top boundary is a pressure outlet at 100kPa and 300K (also initial conditions). The lhs boundary is a stationary wall (fixed boundary plane specification) and the bottom wall (radial axis) is moving according to a grid velocity.
I specify the grid velocity using a field function x(r,t) - which is a combination of an exponential function and a cosine. The grid velocity therefore changes as a function of time and radial position r.
I generate a trimmed cell mesh with prism layers on the moving boundary to capture the high gradients in this region. The models that I am using are:
Axisymmetric, Gradients, IF97 Water (compressible), implicit unsteady, laminar, segregated flow, and segregated fluid temperature.
Here goes my problem:
I initialize the problem and so far all looks good (or as I think it should). Upon trying to step the simulation, the following error comes up:
Non-zero radial coordinate found on axis boundary rhs
Maximum error was :0
Repair boundary using "Project to Axis...".
Command: StepSimulation
error: Server Error
I am surprised by this since I set up the domain/mesh as described in the user-guide for axisymmetric meshes, i.e. i) in Z=0 plane ii) with the axis of symmetry on the x-axis iii) mesh above y=0.
Anyway, I have tried using Project Axis but it still does not work. Instead, a floating point error comes up:
A floating point exception has occurred: floating point exception [Invalid operation]. The specific cause cannot be identified. Please refer to the troubleshooting section of the User's Guide.
Command: Unknown Command
error: Server Error
I think that the problem lies in my field function for the Grid Velocity. I have tried running the exact same thing but with a constant velocity i.e. I specify a constant value directly rather than as a function of exp and cos and it works. I have tried increasing the complexity of the function step by step by introducing the cos and exp function separately. The cos function works but not the exp.
An interesting thing I noticed is that the exponential function contains the dependence on the radial coordinate r i.e. e^br where b is a constant. cos is expressed in terms of time.
Please help.... I do not think this should be that difficult to set up and run
JM27 is offline   Reply With Quote
Old   September 6, 2018, 23:22
Question Hi..Just a doubt!
Ubuntu's Avatar
Siddharth
Ubuntu is on a distinguished road
Will your domain look like a nozzle with variable area inlet in 3D?
Ubuntu is offline   Reply With Quote
Old   September 7, 2018, 05:39
Hi Ubuntu,
No it will not have a variable area inlet in 3D...I am trying to model an ultrasonic cleaning tank.
I want the boundary motion in my simulation to account for the acoustic wave in the tank filled with water...So if I revolve my axisymmetric geometry to get 3D this would look just like a cylinder (or pipe) but with one end closed (moving wall) and the other end open to atmosphere (pressure outlet)...hope this clarifies
Old   September 7, 2018, 10:25
Wink Hi again
Ubuntu's Avatar
Siddharth
Does the attachment look like what you wanted? more or less?
https://we.tl/t-9YMy02OVyQ
I had some free time.
Old   September 7, 2018, 11:01
Default oscillatory boundary motion as function of time and position
Hello again Ubuntu,
Thanks for your reply. Yes looks close enough to what I am trying to do.
The main difference I notice is that in the attached video the oscillation seems to be varying only with time. In my case I need the oscillation to also be varying with position..mainly because I want the motion at the left wall (r=0.06m) to be fixed and the maximum motion to take place at the axis of symmetry (r=0).. in fact that is why i am using an exponential function of the form exp^(-br) in my field function...r is the radial position and b is a constant.
At r = 0 the mesh displacement would be maximum and minimum at r=0.06m (left boundary) the mesh displacement would be zero.
Can you explain how you did your simulation in CCM+ and any suggestions for my case?
That would be very helpful for me, thanks in advance!
Old   September 8, 2018, 01:36
Ubuntu's Avatar
Siddharth
Sure, happy to.
I used the same boundary conditions as you described in your post (see attachment) except that I used laminar, without energy equation terms.
In my case, the axis boundary was along the X-axis, and the mesh was on the XY plane above y =0. I am not sure why it happens to you though you followed all these.
Regarding the morphing motion, I created a simple Field Function which looks like,
sin(2*$Time)
In your case, it will be like
exp(-$$Position[1])*sin(2*$Time)
The location of lab coordinate system is important when you use $$Position[].
Hope this helps you.
Old   September 8, 2018, 09:25
Originally Posted by Ubuntu View Post
Sure, happy to.
I really appreciate you trying to help out!
I am also using laminar However, ccm+ won't let me run without specifying an energy model. I tried both Segregated Fluid Isothermal and Segregated Fluid Temperature and it still does not work
With regards to this problem, I have created a new geometry part (again based on the conditions for axisymmetric model) and regenerated a new mesh and this error no longer comes up
sin(2*$Time)
If you don't mind have a few questions about the morphing itself. It would be really helpful if you could answer these so I can cross-check my simulation setup with yours. I am using the following field function to specify Grid Velocity:
[((($$Position[1] <= 0.06) && ($$Position[0] <= 3e-4) ) ? (( (2*3.1416*33e3)*(0.2e-6) * (cos(2*3.1416*33e3*${Time}))*(exp(pow(-(-2e8)*$$Position[1],6))))) : 0 ),0,0]
I have also tried replacing $$Position[1] with $RadialCoordinate but still won't work. It does work if I get rid of the exp(pow(-(-2e8)*$$Position[1],6)) bit however
1) In your field function, do you use some kind of condition or do you specify the velocity as a vector directly, i.e. [x,y,z] components?
2) What mesh morpher solver conditions are you using? In my case, I'm using Morph from Zero and Recompute Interfaces
3) I was using a Fixed Boundary Plane Specification on my left boundary. I tried it using Floating as in your case but I keep getting this error:
SIGSEGV: memory access exception Command: StepSimulation
Processor: 0
Recoverability: Non-recoverable
ServerStack: [
libStarNeo.so: SignalHandler::signalHandlerFunction(int, siginfo*, void*),
libpthread.so.0(+0xf6d0),
libMorpherModel.so(+0x1534d6),
libMorpherModel.so(+0x1591ce),
libMorpherModel.so(+0x159af6),
libMorpherModel.so: ProMorpher::update(int const&, double const&),
libMorpherModel.so: ProMorpherMap::run(int, double),
libMorpherModel.so: MovingMeshSolverBase::updateThisTimeStep(FvReprese ntation const&),
libMorpherModel.so: MovingMeshSolverBase::commonTimeStepUpdate(unsigne d int const&),
libStarSolve.so: ImplicitUnsteadySolver:: preStep(),
libStarSolve.so: ImplicitUnsteadySolver::step(),
libStarSolve.so: SimulationIterator::startSimulation(RunnableSolver *, int, SimulationIterator::RunMode, bool),
libStarSolve.so(+0x1e6357),
libStarNeo.so: Controller::executeCommand(Command&, Properties const&, Properties&),
libStarNeo.so: Controller:: processCommands(),
libStarMachine.so: CommandController::SerialMasterCommandLoop::start( ),
libStarMachine.so: CommandController:: processCommands(),
libStarMachine.so: Machine::startServerHost(int, char**, std::map<std::string, unsigned int, std::less<std::string>, std::allocator<std: pair<std::string const, unsigned int> > >&),
libStarMachine.so: Machine::main(int, char**)]
Signal: SIGSEGV: memory access exception
error: Server Error
I am running on 16GB ram so again surprised to have this come up. I am running out of ideas to try make this work
Your help is very much appreciated, at least I know I am on the right track Look forward to your reply!
Old   September 8, 2018, 22:26
Ubuntu's Avatar
Siddharth
1. I didn't make it as a vector function. You can specify it as components so that you don't have to create a vector field function (Fig1 and 2)
2. I didn't change any solver settings of morpher (default). I went to respective boundaries and specified morpher conditions for each of them.
3. I am not sure why.
What is the equation you wish to put as field function? I wonder if that conditional statement in your field function is really necessary. May be placing a new coordinate system will help, I think.
Also I made some changes in the field function (Fig3) and did it again.
Check if this looks more like what you want.
https://we.tl/t-Vvft7y2mOc
Old   September 11, 2018, 06:19
Default Motion field function
Hello again Ubuntu,
Thank for your reply and apologies for the delay in reply
I have eliminated the use of the condition in my field function and just specified the components and it works okay. I think the condition is just an extra complication in this case...
Ok, just wanted to double check
Yes, this is more similar because motion at the side wall is fixed.
The equation I am using is of the form: const*exp(const*$$Position)*cos(const*${Time})
After lots of trial and error I figured that the memory access exception error was in fact coming from the field function. I eliminated the condition and declared the two functions, i.e. trigonometric and exponential, as two separate field functions. I create a third field function in which I reference the trig and exp function as vector components.
Still curious as to why it wouldn't work by simply putting the whole definition in a single field function, but I'm glad I finally managed to get the desired motion on the boundary
Hope this helps anyone having the same problem in the future. Thanks a lot Ubuntu for your help
Old   September 11, 2018, 07:50
Thumbs up
Ubuntu's Avatar
Siddharth
Glad to know that you solved it.
axisymmetric, field function, floating point exception, grid velocity, morphing
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
