Understanding Surface Growth Rate
Old   August 13, 2018, 12:02
Unhappy Understanding Surface Growth Rate
Indiana (IN)
alw7 is on a distinguished road
Good Morning,
I am new to CFD and I am learning through STAR-CCM+. I am currently creating a trimmed mesh around a cylindrical geometry. I am trying to understand how to determine what the best surface growth rate would be in the default controls but I am not understanding how that number can be determined.
Thank you!
alw7 is offline   Reply With Quote
Old   August 13, 2018, 12:37
André Pinto
AndreP is on a distinguished road
Originally Posted by alw7 View Post
Good Morning,
Thank you!
The Surface Growth Rate determines the MAXIMUM ratio of growth that one cell can have in relation of the connected cells.
So, imagine. If you have one cell close to the surface with 1mm size, and you have the Surface Growth of 1.3, the next cell will be AT MAXIMUM, 1.3mm! It can although happen that the mesher decides it needs to be 1.2mm ou even 1mm again! It only specifies and control how your mesh will grow away from the Surface.
I don't think there's a mathematical calculation for this. Is one of the parameters that you'll tweaking and reducing, to achieve a better mesh quality and stable results, if needed!
AndreP is offline   Reply With Quote
Old   August 13, 2018, 20:53
me3840 is on a distinguished road
If you are making a trimmed mesh then the surface growth rate is largely irrelevant. Trimmed meshes can only grow and shrink in factors of 2. The surface growth rate will only really affect the mesh in areas of high curvature, which you will have to refine with the trimmer anyway.
me3840 is offline   Reply With Quote
growth rate, mesh 3d, trimmed mesh
Contours of custom surface rate (UDF and UDM) cpassa FLUENT 2 August 14, 2021 14:25
[ICEM] Edge bunshing law and growth rate yonpanman ANSYS Meshing & Geometry 2 October 27, 2016 12:44
[ANSYS Meshing] (Barely) acceptable growth rate bongbang ANSYS Meshing & Geometry 2 July 5, 2015 22:57
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 19:48
Surface reaction rate temperature dependence tumbao FLUENT 1 February 17, 2011 10:14
