August 12, 2018, 13:08 |
Propeller Thrust and Torque Increasing
Rep Power: 8 |
Good Day everyone,
I am running open water test on my propeller but unfortunately my result of thrust coefficient and torque coefficient show increasing graphs. I have been working on the directions of torque and thrust but it doesn't help. Experts can give some suggestions which part to work on? My propeller: negative RPM with axis (1,0,0) negative inlet velocity zero outlet pressure thrust direction (-1,0,0) torque direction (1,0,0) At first I was running using the setting exactly the same as in user guide except the way I created the interface but my result was wrong too. I got my torque and thrust coefficient as decreasing graph but negative value. I was trying to imitate or follow all the setting as in example so I have no idea which part had gone wrong. Last edited by KindaHungry; August 12, 2018 at 13:28. Reason: extra information |
November 3, 2018, 05:59 |
Rep Power: 8 |
Hi I have found the problem to this issue.
The thing is I was using a propeller with pitch ratio P/D 0.8065 but I obtaining result data from J=0.8 to J=1.2. For pitch ratio 0.8065, the torque coefficient, thrust coefficient will increase from low J until around approximately J=0.7 and starts to drop after that and the value can keep dropping to negative values. So what I did was I obtained date from J=0.1 to J=0.8 and the problem is solved. |
Calculation of thrust and torque for propeller | aeksberde | OpenFOAM Post-Processing | 2 | October 28, 2019 05:23 |
How do I find thrust and torque for a propeller in ANSYS Fluent ? | Hayatul_Maruf | FLUENT | 0 | May 14, 2018 00:05 |
how to get thrust and torque from fluent acting on propeller using single enclosure | Naveen Kumar Gulla | FLUENT | 2 | April 12, 2018 07:59 |
calculate the thrust and torque of a propeller in open water condition. | Alex song | STAR-CCM+ | 14 | August 3, 2016 11:54 |
Thrust and torque of a propeller | Alex H | FLUENT | 3 | July 1, 2016 17:00 |
