August 4, 2018, 00:21 |
Floating Point Exception
Rep Power: 8 |
Hi Good Morning!
I have been running using my propeller and this error came out : "A floating point exception has occurred: floating point exception [Divide by zero]. The specific cause cannot be identified. Please refer to the troubleshooting section of the User's Guide. Context: Field function Iteration Command: RunSimulation error: Server Error" Referring to User Guide, it mentioned about solver and initial conditions. In solver, I have ticked "Temporary Storage Retained" in K-Epsilon Turbulence". That is the only changes i did for solver. In initial conditions under Physics, I changed the density to 998.67kg/m3 and dynamic viscosity to 0.001068Pas, that's it. So is my input number wrong or is there other solutions? Thank you very much! |
August 8, 2018, 02:00 |
Rep Power: 25 |
Did you create a field function named iteration?
This problem is usually mesh related otherwise. Please post pictures of your mesh and describe the case. |
August 8, 2018, 02:25 |
Rep Power: 8 |
Hi me3840,
Thanks for the advice, I have solved the problem of floating point. Thank you very much =D |
August 8, 2018, 03:12 |
Rep Power: 9 |
August 8, 2018, 05:51 |
Rep Power: 8 |
I redo all my setting then it can run already, probably careless mistake ><
floating point exception, propellers, star ccm+ |
icoFoam floating point exception (8) | leizhao512 | OpenFOAM Running, Solving & CFD | 7 | November 1, 2018 12:43 |
A floating point exception has occurred: floating point exception [Overflow]. | starlight | STAR-CCM+ | 4 | May 4, 2016 10:08 |
A floating point exception - SEM Model | yansheng | STAR-CCM+ | 1 | April 4, 2016 05:57 |
Floating point exception from twoPhaseEulerFoam | openfoammaofnepo | OpenFOAM Running, Solving & CFD | 1 | March 19, 2016 14:56 |
Floating point exception (core dumped) for GAMG solver | yuhou1989 | OpenFOAM Running, Solving & CFD | 2 | March 24, 2015 20:28 |
