Warning: Pressure and Temperature correction limited to N cells in region
Old   June 12, 2018, 04:39
Default Warning: Pressure and Temperature correction limited to N cells in region
JOHN SHERJY SYRIAC
johnsherjy is on a distinguished road
Hello.
I intend to simulate unsteady flow over a rotating helicopter blade.. I meshed it using overset mesh technique with refinement near the surface with 3.7 M cells. On runnning, Pressure and temperature correction is limited to 100 cells..and max temp is limited to 5000K is shown during every iteration( please see the attachment).Residual plot looks unsatisfactory.. Why does this happen?...Can anyone suggest a solution to avoid this....Thanks in advance...
johnsherjy is offline   Reply With Quote
Old   June 12, 2018, 15:58
Matt
fluid23 is on a distinguished road
First thing I would check would be your y+ values and make sure they are appropriate for your wall model. Second, I would make sure you don't have any localized shocks that would need to be resolved by mesh refinement. Third, make sure your time step is appropriate.
Just out of curiosity, how many degrees per time step does your rotor translate?
fluid23 is offline   Reply With Quote
Old   June 12, 2018, 23:47
JOHN SHERJY SYRIAC
Hi...i am doing a case of hover condition with 424 rpm....my time step is 7.86*10^-4s ie 2 deg rotation...my y+ values are <1 expect at wing tips....
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
temperature limited warning in 1 cell Shamoon Jamshed FLUENT 1 April 3, 2014 05:00
UDF for Back-flow Temperature G340 Fluent UDF and Scheme Programming 3 August 21, 2013 05:56
reversing flow Martin Siemens 14 March 18, 2009 09:07
